I need help about liquid cooling
Hi guys im new to this forum and this will be my first post
My rig is using a stock cooler and i want to upgrade it. So im wondering which one of these 3(or some others around their price range) would u guys recommend: Cooler Master Nepton 280L NZXT Kraken X61 CORSAIR Hydro Series H110i GT
IM also wondering which one of these could fit into my Thermaltake dokker chassis couse i cant find the info i need online
Hey
welcome to the forums
1.Please post in the right sub-forum;)(Watercooling in this case)
2.If you are new please read the Code of conduct (http://linustechtips.com/main/topic/95599-linus-tech-tips-forum-code-of-conduct/)
3.Have you asked yourself if you want to Watercool there are Aircooling options that perform nearly the same as some of these Liquid coolers(Noctua NH-D15)
4.NZXT Kraken masterrace!
and also look at the x41 it performs nearly as good if not better than some 240m Coolers
5.Nzxt's Kraken series performs very well with good fans;) (tip)
