I want to build an HTPC for my living room.
I am looking for some tips to help me get started.
What sound card makes sense for the speaker set up?
What are some good HTPC cases?
Do I need a cheap graphics card initially if I plan on saving up and buying a better one later?
Does anyone suggest a TV tuner for an HTPC?
Is there a good place to look for tips on LTT or any other site?
Any suggestions or tips are appreciated!
Speakers
Receiver: Marantz SR7007
BookShelf: HSU Research HB-1 MK2  (x4)
Center: HSU Research HC-1 MK2
Subwoofer: HSU Research VTF-15
Total Cost: $3,400
CPU: i7 -4770k Cooler: H100i Mobo: G1.Sniper Z87 Memory: Corsair Vengeance 16gb 1866mhz SSD: Samsung 830 128gb HDD: WD 1TB Black GPU: EVGA GTX 780 ACX Cooler PSU: SeaSonic X Series X650 Gold Speakers: Corsair SP2500 Case: CM Storm Stryker Fans: Corsair AF & SP Fans
[spoiler=Ultrabook : Aspire S7 392-7863]CPU: i7-4500U (1.8GHz/3GHz) Memory: 8GB DDR3L-RS SSD: 256Gb (RAID 0) Display: 13.3" IPS Multi-touch (2560 x 1440)
https://linustechtips.com/topic/403146-htpc-help/
Most modern motherboards have decent sound. As a general rule, the better the motherboard chipset, the better the sound.
A current model i3 can easily handle the graphics requirements of an htpc.
Silverstone makes a number of good looking htpc cases. Most notable is the Raven RVZ01. Fractal Design has just introduced the Node 202 which is also a decent case.
https://linustechtips.com/topic/403146-htpc-help/#findComment-5436291
Is there any benefit to having a sound card with my set up?
Thanks for the reply!
https://linustechtips.com/topic/403146-htpc-help/#findComment-5436594
Short answer, depends on the motherboard and speakers. I would suggest asking the question in http://linustechtips.com/main/forum/40-audio/. You will get a much more informed answer there.
https://linustechtips.com/topic/403146-htpc-help/#findComment-5438331
Thanks for your help!
https://linustechtips.com/topic/403146-htpc-help/#findComment-5446987
