Hello! I plan on reapplying my thermal paste on my CPU with IC Diamond. I currently have an i7 3770k and wanted to ask if these steps are correct-
1) Use ArctiClean to remove any paste
2) Remove and clean surface using lint free cloth
[i'll be using http://www.amazon.co.uk/Professional-Supersoft-Cotton-Polishing-Cloths/dp/B001MPSSYC/ref=sr_1_6?ie=UTF8&qid=1374981107&sr=8-6&keywords=lint+free]
3) Apply new thermal paste [5mm in diameter in the middle of the CPU]
4) Enjoy!
Is the cleaning cloth and pea size I have mentioned correct? [i already have them with me]
PC in Profile
https://linustechtips.com/topic/40258-cleaning-thermal-paste/
Yep, seems perfect to me.
Goodluck!
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/40258-cleaning-thermal-paste/#findComment-520338
Yes. You are doing it right.
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/40258-cleaning-thermal-paste/#findComment-520360
Seems great. Just curious, what CPU cooler do you use?
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/40258-cleaning-thermal-paste/#findComment-520362
Yup, If you didn't have that cleaner rubbing alcohol works just as well,
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/40258-cleaning-thermal-paste/#findComment-520413
