Can I leave this open like this?
Is it dangerous? (Can the cables sticking out get damaged?)post-124496-0-83013600-1436310456_thumb.
CPU: Intel Core i5 4460 3.2 Ghz \\ Motherboard: MSI H97 PC MATE ATX \\ RAM: Corsair 2x4 GB 1600 Mhz \\ GPU: Asus Strix GTX 970 4 GB DDR5 \\ Storage: WD Caviar Blue 1 TB, 7200 RPM and an external WD Elements 1 TB HDD \\ PSU: Corsair VS650W \\ Case: Cooler Master K350 \\ Optical drive: Samsung R/W 24x \\ OS: Windows 10 64-bit \\ Keyboard/Mouse: Both DELL \\ Display: Samsung 28-inch TV 1080p 60 Hz \\ Phone: Samsung Galaxy S5 Electric Blue 16 GB
https://linustechtips.com/topic/402573-case-and-cable-managment/
Is it dangerous? (Can the cables sticking out get damaged?)attachicon.gif2015-07-08 01.06.47.jpg
You're actually more likely to do damage with the side panel on as you'll put more tension on them. In my case which has so little space behind the motherboard tray, occasionally my hard drives won't be recognized by the BIOS because there's too much pressure on the SATA power cables.
You should be fine, just don't throw coffee at your PC.
https://linustechtips.com/topic/402573-case-and-cable-managment/#findComment-5427745
Thank you very much! :D
https://linustechtips.com/topic/402573-case-and-cable-managment/#findComment-5427759
