I need an air cooler for a 2011-3 socket
If you care, the case is an ATX case, if you care even more it is the Fractal Design Arc Midi R2 and if you care more the size is 230 x 460 x 515mm in size. But if you don't care that's fine too.
Any suggestions?
Thx
--FTPCraft
https://linustechtips.com/topic/402568-cooler-suggestions/
Any suggestions?
Thx
--FTPCraft
Noctua NH-D15 or CRYORIG R1 ULTIMATE
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/402568-cooler-suggestions/#findComment-5427631
Well, we don't care which case you use. But you should care how much it has space for cooler. Lucky for you, that case has full 180mm clearance. You can pick anything that fits the budget. Like the top models from which two is listed above. Phanteks PH-TC14PE being third.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/402568-cooler-suggestions/#findComment-5432621
What are you cooling?
https://linustechtips.com/topic/402568-cooler-suggestions/#findComment-5458454
