Today when i tried to download a new game on steam my Download speed was only about 1.4mb/s peak. I usually have about 10mb/s so this is pretty weird. What could cause the download speed to go down this much, i closed all other programs on my pc.
Here's my Ookla speedtest right now: http://gyazo.com/da3708d895c916a84f092b8f51a61608
Build: GPU: MSI GeForce GTX 780 CPU: Intel i5 4690 MoBo: AsRock Fatal1ty H97 Killer RAM: Kingston HyperX Beast 16GB PSU: Seasonic 550W 80+ Gold Case: Corsair Obsidian 500R
https://linustechtips.com/topic/402249-download-speed-limited/
restart your router/modem/everything
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5422914
another guy on here is having problems with steam to
so its probably steams fault
look at his speedtest
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5422934
This.  Also, is anybody in your house doing any heavy streaming or downloading?
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5422936
Not hijacking the thread but I have a similar problem, only I'm downloading from the R* website. I get this problem only when downloading gta 5, tried other downloads, worked perfectly
Longboarders/ skaters message me!
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5422938
That speed seems fine to me, nothing wrong with 1.4 Mb/s.
Steve Wozniak - "Never trust a computer you can't throw out a window."        Carl Sagan - "If you want to make an apple pie from scratch, you must first create the universe."
CPU: Core i5 6600K Cooling: NH-D14 Motherboard: GA-Z170XP-SLI RAM: 8GB Patriot Graphics: Sapphire Nitro R9 380 4G Case: Phanteks Enthoo Pro HDD: 2TB Seagate Barracuda PSU: Threamaltake Smart 750W
My computer runs on MSX, Its very hard to catch.
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5422947
Sure, but it's lower than his regular download speed.  Just because it's a good speed doesn't mean problem solved.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5422959
Nothing wrong with 1.4 Mb/s in itself, but i usually have 10.
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5422967
Because you're downloading? Other people might be using the internet connection.
@Rappelin
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5422975
well then it's probably rockstars fault
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5422978
There seems to be a bit of confusion.
When you performed the speed test, can you verify whether any other user in your house was using the Internet? Can you verify if you were downloading or streaming anything from the Internet at the same time?
Basically, speedtest should be run by itself, with no other internet activity, to give you an accurate result.
If you've verified that Speedtest was run by itself, and you're still getting the results of 2.69 Mbps, then you should call your Internet Service Provider, and get them to test your line.
Also, Steam reports download speeds in MB/s, (Megabytes per second). Your ISP, and speedtest, report speeds in Mbps or Mb/s (Megabits per second). Big difference.
10 Mbps = 1.25 MB/s. So if you pay for 10 Mbps internet, you can expect download speeds of ~1.25 MB/s.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5424341
If a single website is giving you slow speeds, but all others are fine, then the fault is on their end, not yours. Likely, the Rockstar website is just experiencing some higher than usual volume of users.
Also, in the future please make a new thread for stuff like this, as it's a different situation :) We don't want the OP's issue to get lost in the mix, and you will receive better attention to your problem.
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5424359
Just asked dad, he said we have a 100 Mbps internet connection. So that should belike 12,5 MB/s when downloading something, right?
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5431565
Yes that's correct, a 100 Mbps connection equals ~12.5 MB/s download speeds.
However, if that is indeed the connection you're paying for, then something is seriously wrong with your speed test. Your speed test results literally show your speed at 2.69% of your connection. I don't think I have to tell you how bad that is.
Can you reply to the rest of my post? Did you run the speed test by itself with no other users using the internet? We need more clarification.
https://linustechtips.com/topic/402249-download-speed-limited/#findComment-5433117
