EK Premix or Distilled Water?
Solved by W-L,
From reading up the the EK nickel blocks and silver issue it seems they are borderline dis-similar metals in "harsh environments" so it can cause the nickel to flake and come off.
So using a clear Premix or distiller with a biocide like PT Nuke is the best solution to colored fluids. Both will be fairly easy to maintain the loop with no staining or need for aggressive flushing to remove any color from rads.
Featured Topics
MahdiC ·
Posted in Networking1 -
Sychicyuto ·
Posted in Troubleshooting2 -
ItzEager ·
Posted in Troubleshooting3 -
TheIndecisiveMollusk ·
Posted in New Builds and Planning1 -
4
Agall ·
Posted in CPUs, Motherboards, and Memory4 -
3
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
