My cpu is not overclocking? The target speed is set at 4.0 but the speed it at now is still 3.5....
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
https://linustechtips.com/topic/401970-cpu-not-overclocking/
Power setting in windows?
what?
Join da discord
https://linustechtips.com/topic/401970-cpu-not-overclocking/#findComment-5419621
Control panel>hardware and sound>power options and select balanced
I am on balanced
Join da discord
https://linustechtips.com/topic/401970-cpu-not-overclocking/#findComment-5419642
Please send specs
specs are in my Sig.
Join da discord
https://linustechtips.com/topic/401970-cpu-not-overclocking/#findComment-5419653
AMD FX 8370E info.
E stand for energy efficient. I don't believe it can overclock. Try turning just base frequency like linus did with his 18 core cpu video.
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/401970-cpu-not-overclocking/#findComment-5419705
AMD FX 8370E info.
I did it. Its fixed now. im at 4.1 with a corsair H55 cooler. and im about 19 degrees.   Do you know any stress tests i can use to make sure its stable?
Join da discord
https://linustechtips.com/topic/401970-cpu-not-overclocking/#findComment-5419765
Prime 95, Cinema Bench, just watch some of linus videos. FYI: Also MArk Solved on my last post.
Chase B
https://linustechtips.com/topic/401970-cpu-not-overclocking/#findComment-5419775
Can i run cinemabench all night?
Join da discord
https://linustechtips.com/topic/401970-cpu-not-overclocking/#findComment-5419798
No. Use Prime 95.
36 degrees is good stable temp for 100% stress while overclocking i assume?
Join da discord
https://linustechtips.com/topic/401970-cpu-not-overclocking/#findComment-5419847
