hey, anyone know bout' a good fan controller that works with the motherboard (asus ROG maximus VII Ranger), without buying any fan controllers like corsair commander
Basically a fan splitter like the one starcoaster linked for PWM only fans. For 3 pin you will need 3 pin splitters. The rule of thumb is 3-4 fan per motherboard fan header.
https://linustechtips.com/topic/401811-pc-fan-controler/#findComment-5417480
or use one with a power cable to the PSU and drop the loading on the motherboard altogether.. Much safer option
That won't let you control the fan however it will give you an RPM line for 3 pin fans. This however works great for 4 pin PWM fans.
https://linustechtips.com/topic/401811-pc-fan-controler/#findComment-5417560
