so im going to put mac on my pc and ive checked and it will work but i want to know if i will still be able to boot to the bios when i get it set up e.g so i go into the bios to change the hdd to boot to e.g windows or mac
e.g when it powers up it shows the bios splash screen and then boots into mac os
My speakers dont even fit on or under my desk...PA's FTW
https://linustechtips.com/topic/401793-hackingtosh-help/
First find the drive OS X Is installed on, then find your disk boot order.Change it to the OS X drive. On some bootloaders, you are able to boot into windows from the OS X Drive.
Sorry if I was not detailed enough. I don't know the exact BIOS layout for I still use an EFI, not UEFI, but what I do know it is under Advanced.
You are on a need to know basis, and you don't need to know.
https://linustechtips.com/topic/401793-hackingtosh-help/#findComment-5417187
ive got a UEFI bios
https://linustechtips.com/topic/401793-hackingtosh-help/#findComment-5417211
