can you guys help me complete this build, I don't want to go over 800$ but still want a good gaming computer. Also want a good PSU(maybe 700w-750w?) so I can upgrade my computer in the future,
I live in canada so want the shipping to cost to much either
http://pcpartpicker.com/p/CXKhLk
also, can you tell me if the hyper 212 evo would fit in this case? if so, don't need to add a cooler to the mix (not planning to overclock)
https://linustechtips.com/topic/401109-need-help-completing-my-build/
http://pcpartpicker.com/p/tGFbHx
an updated list only $13 over
and no the hyper 212 evo would not
http://pcpartpicker.com/p/b3D77P
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
Canada, change the ssd if you want, I don't mind
mostly gaming on the computer
You are using the american pcpartpicker
http://pcpartpicker.com/p/qjxRxr
Try and get that in canada
U can get a cheaper PSU if need be
212 wont fit in that case
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
Get a SSD as a upgrade when you get 60$ more.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($218.50 @ shopRBC)
Motherboard: MSI B85-G41 PC Mate ATX LGA1150 Motherboard ($89.32 @ DirectCanada)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory ($52.91 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($60.75 @ Vuugo)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card ($234.00 @ NCIX)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($48.99 @ NCIX)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($84.99 @ NCIX)
Total: $789.46
Generated by PCPartPicker 2015-07-05 16:42 EDT-0400
Total: $789.46
does the evo 212 fit in that case?
I wouldn't bother trying to fit the 212 in that case, it will, but with quite a few risks.
/╲/\╭( ͡° ͡° ͜ʖ ͡° ͡°)╮/\╱\
01010011 01000101 01001110 01000100 00100000 01001000 01000101 01001100 01010000 00101100 00100000 01010000 01000101 01001110 01000111 01010101 01001001 01001110 01010011 00100000 01000101 01010011 01000011 01000001 01010000 01000101 01000100
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($68.98 @ Newegg Canada)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory  ($58.99 @ Canada Computers)
Storage: Patriot Blaze 120GB 2.5" Solid State Drive  ($59.99 @ NCIX)
Total: $808.19
Generated by PCPartPicker 2015-07-05 18:41 EDT-0400
"THE RED ARMY"
| INTEL i5 4690K | GIGABYTE Z97X GAMING 3 | XFX R9 390X | CORSAIR VENGEANCE PRO 4x2 8GB 1600Mhz | CORSAIR H80i | XFX XTR 650W | 1TB WESTERN DIGITAL CAVIAR BLUE | ADATA SP600 256GB | LOGITECH G502 | CORSAIR VENGEANCE 1400 | CORSAIR K70 MECHANICAL RED | NZXT S340 |
before i make any recommendations, i need the following:
  • do you need a keyboard, operating system, mouse, and monitor included in the budget?
  • wifi or ethernet?
  • overclocking the cpu and gpu?
  • when do you plan on upgrading?
thanks
BigDay
Here's my build
Cpu: Intel Pentium g3258
Gpu: msi r7 265
Ram: crucial ballistix sport 8gb
Hard drive: Western digital caviar blue 1 tb
Psu: corsair430 w
- I need help in choosing a motherboard that would be best for this setup. I plan to play games, some recordings and video editing.
-These are some mobo's I've been thinking about cause I'd like to over clock and their under $100
Can you list best to worst
-MSI H81M-E34 Micro ATX LGA1150 Motherboard
-Gigabyte h97
-Gigabyte ga-z97-hd3
-Gigabyte lga 1150 Intel h97
-Gigabyte h97extreme multi graphic support
-ASRock Z97 Anniversary ATX LGA1150 Motherboard
-ASRock Z97M Anniversary Micro ATX LGA1150 Motherboard
Thx for your help:)
