What power supply do i need?
Solved by Guest,
what if i at some point add another 980 ti? will i need even more then the hx1000i then?
thx for the responce sofar
An 850W would be fine for a 2nd card. If you are going to be overclocking the cpu and gpu's then go with 1000W as X99 cpu's are a bit more power hungry than Z97.
I would look at EVGA psu's as they are usually cheaper than Corsair. The EVGA G2/GS 850W, EVGA G2/P2/PS 1000W and EVGA GS 1050W are all very good.
