Get the OS from G2A or Reddit.com/r/microsoftsoftwareswap
They're legit copies and 1/5th the price.
Other than that, i see no problems. Nice build, hope it works out great for ye. you might also consider a 1440p or widescreen 1080p monitor. A 980ti is a little overkill for just 1080p 144hz.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/400612-build-2600-help/#findComment-5400478
Why not just go X99 ?
I would highly suggest getting a cheapo keyboard and mouse and then upgrading
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($378.99 @ SuperBiiz)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($114.99 @ Amazon)
Motherboard: MSI X99A SLI KRAIT EDITION ATX LGA2011-3 Motherboard  ($269.99 @ Amazon)
Storage: Intel 730 Series 240GB 2.5" Solid State Drive  ($132.75 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($699.95 @ B&H)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($249.99 @ Amazon)
Headphones: Sennheiser HD 598 Headphones  ($150.99 @ Amazon)
Total: $2557.52
Generated by PCPartPicker 2015-07-04 20:39 EDT-0400
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/400612-build-2600-help/#findComment-5400529
Building my first big/expensive PC. Was wondering if anyone could help me out with parts. Dont want to spend more than $2600. Here is the link. >
http://pcpartpicker.com/p/M2s823
The issue i was having was choosing i5 or i7, motherboard, and graphics card.
What is the pc being used for ?
https://linustechtips.com/topic/400612-build-2600-help/#findComment-5400595
