Hi, I have HyperX Fury 8GB 1866Mhz RAM.My OS is Windows 8.1.....But in Task Manager the RAM Speed is 1333Mhz Only.but in BIOS i have the speed of 1600Mhz.So,Is This normal on Windows 8.1..If its not,Then how do i change it ?
Intel i3-4150 3.50Ghz | MSI B85M-G43 | HyperX Fury 8GB 1866Mhz x1 | Intel HD 4400 | WD Caviar Blue 500GB , Samsung 160GB | Odyssey 450W | AOC E950Sw 18.5In | Windows 10 Pro | Zebronics Armour 2
https://linustechtips.com/topic/400279-ram-speed-problem-on-windows-81/
Are you sure you have the RAM set to 1600MHz? What does CPU-Z say?
Help ?
Your frequencies are where they should be. CPU-Z is more accurate than Windows.
