Hi everyone, I´m having problems with my old pc (HP Pavilion t780). Yesterday I was running the antivirus and finally it asked for a reboot when it finished. Then, while restarting it suddenly locked itself, and the screen that says: "WINDOWS IS STARTING UP..." remained fixed the whole time and nothing happens. So I just unpluged the pc, and powered it on again, but the same bug occurs over and over again. CAN ANYONE SUGGEST ME WHAT TO DO? I do not want to lose my hard drive files.
https://linustechtips.com/topic/400277-help-please/
try safe mode first
see if it will boot to windows
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/400277-help-please/#findComment-5403263
