I already have a case(ATX), a DVD drive, and a 550w PSU and have given myself a budget of $600. I'm planning on getting an ASRock 980 mobo, AMD 8320 CPU, HyperX Fury 8GB RAM stick, Sapphire 270X GPU, Western Digital Blue 1TB HDD, and the CM Storm Devastator keyboard and mouse combo.
Is this decent enough to get me started in the gaming community? If you have another build that would fit the budget WITHOUT the case, PSU, and optical drive feel free to comment it.
https://linustechtips.com/topic/400123-first-pc-build/
You can get a lot better with this budget
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($166.95 @ SuperBiiz)
Motherboard: Gigabyte GA-H97-HD3 ATX LGA1150 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill AEGIS 8GB (2 x 4GB) DDR3-1600 Memory  ($46.99 @ Newegg)
Video Card: MSI Radeon R9 290 4GB TWIN FROZR Video Card  ($262.98 @ Newegg)
Total: $611.79
Generated by PCPartPicker 2015-07-04 01:30 EDT-0400
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/400123-first-pc-build/#findComment-5393737
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($27.99 @ Amazon)
Total: $611.79
This is exactly what I was thinking and is a solid plan, just interested what power supply do you have?
https://linustechtips.com/topic/400123-first-pc-build/#findComment-5393765
Modular
Does it have a name or label?
https://linustechtips.com/topic/400123-first-pc-build/#findComment-5393780
I don't have it on me at the moment. It is at my place of work. I pulled it off some older pc's. I know It would be better for me to get a new one but I've tested it by booting up the pc and it runs fine
There is also a xfx r9 290x for 279.99 in case you are interested.
https://linustechtips.com/topic/400123-first-pc-build/#findComment-5393812
Hey there,
Your plan seems pretty good. WD Blue is a great drive for such types of builds.
I'd go for 2x4GB of RAM instead of 1x8GB to make a better use of the dual-channel support of the motherboard (unless you are planning on upgrading to 16GB down the road). :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/400123-first-pc-build/#findComment-5411588
Sounds sketch
https://linustechtips.com/topic/400123-first-pc-build/#findComment-5426925
