Hi, im building my first PC gaming so i really excited, so i wanna know which games i can run with this build and if i can run it with which quality settings and fps, i hope im not asking too much :
- Intel Core i5-4690K 3.5Ghz
- Gigabyte GeForce GTX 970 WindForce 3X OC 4GB DDR5
- G.Skill Ripjaws X DDR3 1600 PC3-12800 8GB 2x4GB CL9
- Gigabyte Z97X-Gaming 7
- SSD Samsung 850 EVO 250GB
Thanks.
https://linustechtips.com/topic/400095-first-pc-build/
1080p? Highest settings across all games. What games are you playing?
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393419
PSU? Case?
How do these contribute to framerate/quality settings?
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393428
Nothing but psu is very important for the PC not blowing up, case not so much.
I suspect you didn't fully read the OP's question...again.  :P
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393448
Without a PSU [Power Supply] none of these components will function. You can go without a case but you will have everything out in the open and thats not always safe. I suggest you use pcpartpicker to create your build or find popular builds on the internet. CultOfMush has some great builds.
Intel i5 4690k | NZXT Kraken x61 | MSI z97 Gaming 5 | MSI GTX 970 EVGA Supernova G2 750 G-Skill Ripjaws 16GB 2133mhz [2x8] | Western Digital Caviar Blue 1TB HDD Samsung 850 EVO Series 250GB SSD NZXT H440 [black and Red]
Saving for a Dream rig :)
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393455
It was a rhetorical question.
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393468
Also i was wondering if i should upgrade ram from 8GB to 16GB.
For just gaming no, you will only need 8 gigs. No game uses anymore than 8. But if you plan on doing some big video editing then 16 should defiantly be considered.
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393483
Right now what im playing ? : League of Legends and Minecraft, my laptop can't handler anything else.
You need not worry the capability of this hardware in this case.
8GB is fine
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393488
PSU : Tacens VALEO V 700W, i thought it was unecessary for my question.
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393490
Seems like I'm the only one who gave you the benefit of the doubt. :P
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393493
I don't think any computer can run batman AC properly.
Yeah, the games kinda messed up on pc.
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393498
I saw that on so many forums but, what if i have google chrome and skype open ? Right now google chrome is using 1 GB of ram it alone... And i use Skype to talk with my friends that's why i was wondering if 8 GB won't be enough.
Edit : i haven't bought the graphic card yet so i wanna know if a 980 will be worth.
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393505
I dont think google chrome should use 1 gig of ram... It uses next to nothing on my laptop.
https://linustechtips.com/topic/400095-first-pc-build/#findComment-5393518
