Hi guys,
I currently have a corsair 760 t with the 3 fans that came with it. I want my PC to be as quit as possible at idle so I will buy some Low noise fans from Noctua and corsair and a NH-D15. In total my system will have 9 fans after the upgrade. My question is, do I need a fan controller to control the RPMs of all the fans? If yes which one should I get?
https://linustechtips.com/topic/399638-do-i-need-a-fan-controller/
Hi guys,
Just use some fan splitters.
http://www.amazon.com/SilverStone-Technology-Sleeved-Splitter-CPF01/dp/B00B46XKKQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1435926519&sr=1-1&keywords=fan+splitter
http://www.amazon.com/Silverstone-Technology-Sleeved-Splitter-CPF02/dp/B00HJOJS9O/ref=sr_1_13_m?s=pc&ie=UTF8&qid=1435926666&sr=1-13
And how do i control the speed of the fans? I heard you can do this with ASUS Ai suite
The bios does it automatically, and you manually edit the bios settings, but the functionality is a bit limited.  AI suite is okay, but also a bit limited imo.  I would recommend SpeedFan as you have the most customizability, and it is very light weight.
This is what mine looks like
You should be able to control this from inside the BIOS. Though I do not know if 2 fans are connected to 1 fan header using a splitter and you set the header to be at 30% RPM, will both fans run at 30% RPM or if you will be able to control each of the 9 fans individually.
Also to be "as quiet as possible" you should be aiming for as little fans as possible, not 9 slow speed fans.
Quote me if you want me to see your message. Like my post if it helped. Click "Show More" to see things that I use.
Desktop (2014): CPU: Intel Core i5 4690k @ 3.50GHz | GPU: MSi GTX 970 Gaming 4G | Motherboard: MSi Z97 Gaming 5 | RAM: 2x4GB G.Skill RipJaws X 1600MHz + 2x4GB HyperX Black 1600MHz | SSD: Samsung 750 Evo 120GB | HDD: WD Black 1TB | Cooler: Cooler Master Hyper 212x | PSU: Corsair VS650 | Case: Cooler Master Elite 431 Plus | OS: Windows 10 Home
Laptop (2017): Model: Asus UX310U
Peripherals: Monitor: Samsung S24D300 OC@75Hz + Viewsonic XG2401 (144Hz) | Mouse: Logitech G305 | Keyboard: Razer Blackwidow Chroma V2 | Headset: HyperX Cloud Core | Speakers: Logitech Z333 | Additional: Logitech G29
Mobiles: Samsung Pixon (2010-2012) | Samsung Galaxy Ace (2012-2013) | Samsung Galaxy S3 (2013-2016) | Samsung Note 4 (2015)(Lost) | Samsung Galaxy S7 (2016-2019) | Samsung Galaxy S10 (2019 - Current) | Additional: ASUS Zenwatch 2 (2016)
Thanks! I will consider putting less fans in my case
You could download Speedfan, it allows the fans to be off until the measured component gets to a specific temperature then the set fans will start spinning up (thats as quiet as it gets)
Get Speedfan here: http://www.almico.com/sfdownload.php
Thanks for the tipp
Hi guys,
The way I see it, you have 3 options.
  1. Software based fan controller where the fans are connected to the motherboard
  2. 5.25" bay fan controller
  3. Internal fan controller
In terms of the software route, the only real option is SpeedFan, which I fucking hate. It's finicky and not very intuitive.
For the external fan controller, look up some reviews (I'm not big on them).
The route I personally went is to go with an internal fan controller. I'd say there are two options for going this route, either get an NZXT Grid+ or a Corsair Link Commander Mini.
The NZXT Grid+ is pretty cool. I personally have one and I really like it. The software with it is okay, not amazing, but okay. It's very discrete and you can use up to 6 fans (so you may have to use a splitter). It's also not that expensive. The downside is that it only takes 3-pin fans and doesn't have individual fan control.
The other option, which I kind of wish I had gotten, is the Corsair Link Commander Mini. This thing is fucking cool. You can use up to 8 PWM fans (so you may still have to use a splitter), you can control LED lighting strips from it, the software looks really cool AND it has individual fan control! You can also set up profiles so if your GPU starts running hot, you can turn up your intake fans on the front to feed it with more air but keep every other fan at the same speed. The downsides are that I haven't heard of many people who own and use one (despite asking), and it's also more expensive than the Grid+.
I'd take the Corsair Link, it looks pretty discrete and has got some pretty cool features.
EDIT: You can also create custom fan curves on either internal fan controller.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
Thanks for the extensive description. I might look over the Corsair Link Commander Mini
  • 2 weeks later...
Hello again,
I got my new fans installed and downloaded speed fan. Your screenshots got me wondering about some things.
My question is, what das "Method: MAX of speeds" mean and why did you choose your CPU cores and your GPU as thermal sensor? Does that mean that when ether one of the 5 sensors measures for example 40C° the fan will spin with for example 500 RPM? Or do all 5 sensors need the measure above a certain temperature?
I hope my questions are worded clear enough.
Hi guys,
What mobo do you have? Asus has great integrated fan control, i'm running 7 fans on it, and with an extra splitter im sure i could have more. I don't think running fans according to GPU temps is very effiecient unless you have a custom watercooled build, since the fans on the GPU will take care of it much more effectively
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
I have a Asus Maximus VII Formula. It has 6 fan connectors + 1 CPU fan connector + CPU opt fan connector. Oddly enough in the bios I can only monitor 3 chassis fans the CPU fan and the CPU opt fan even though I plugged in all 8 fans.
I have a Maximus VI Formula, anything that says OPT is not controlable, so in reality you have 4 controlable fan headers. However, 3 pin/PWM splitters are very cheap and you can for example, use one header for front intake, one for top, one for rear and one from the CPU cooler, you can easily plug 3 fans in a single header, so, if you hide that cable mess tidely (Not hard at all) you can have total control and looks decent. I am controlling 7 fans using 3 splitters with my mobo
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
I just checked, the fan headers are labeled A1, A2, A3, B1, B2, and B3. It seems like only the fans that are plugged in in an ‘A’ slot are shown in the BIOS and therefore controllable (3 pin and 4 pin).
I currently have my two front intake fans connected with a splitter and plugged in an ‘A’ port. My bottom intake fan is plugged in an ‘B’ port and my rear exhaust fan is plugged into an ‘A’ port as well. Two of my 3 top exhaust fans are connected with a splitter and plugged in an ‘A’ port and the third Fan is plugged into an ‘B’ port. It also seems like the fans in Port A1 and B1 same with same with fans in A2 and B2 are running at the same speed, could this be possible?
PS: Is it possible to connect 3 fans with 2 fan splitter into one 4 pin port?
I think it is possible but it's easier to buy a 3way splitter
http://www.amazon.com/gp/product/B00B46XKKQ/ref=s9_simh_gw_p147_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=desktop-1&pf_rd_r=0TBK6GW1MJCD8Z88PDM0&pf_rd_t=36701&pf_rd_p=2079475242&pf_rd_i=desktop
I don't know if there is a correspondance with the B headers to their respective A headers, for me it only makes the fan go 100% if I plug it on an OPT header, so i only use the CPU and 3 controlable chassis headers.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
OK I will buy a 3 way splitter. Thx :)
Hello again,
Max of speeds just means that it goes through each of my 5 fan curves, and sees which one is currently the highest fan speed and will use that value.  For example, if Core 1 is only 50C and the fan curve tells it to go to 40% fan speed, and lets say Core 2 is 60C and the fan curve tells it to go to 55% fan speed at that temp, it will choose the higher value, 55%.  The other option is Sum of Speeds, which would just add both values together and use that speed, to 40% + 55% = 95% fan speed.  I haven't found sum of speeds very useful honestly.
But yes, for each of the case fans I use the core temps and the gpu temps.  For the CPU fans I only use core temps for the fan curve, since increasing the cpu fan speeds won't help cool the gpu, in fact it does the opposite, by pulling away air that would have gone to the gpu.
