Corsair c70 Side intake
Go to solution Solved by mgsstar,
I currently have a side intake on my C70 and to me it isn't blowing in alot of dust even though its not filtered but you could always get a SIlverstone air filter if you have a dusty place/want less dust entering like @Samdb said.
Hi guys,
So I am going to get some 140mm fans to put on the window of my case, but the only thing that worries me is that, there's not many 140mm fans, mains one I know is the Corsair AF 140 and the fact there is no fan filter, will dust be an issue? as there will be positive airflow.
Galaxy: Intel i7 3770k @ 4.5Ghz (Cooled by a h105) - ASUS Sabertooth Z77 - Corsair Vengeance 8gb Ram - Nvidia GTX 780 2 way Sli - Corsair HX850i - Corsair C70
Razer Blackwidow Ultimate Battlefield 4 Collectors Edition (TO BE REPLACED BY K65 RGB) - Logitech G502 - Hyperx Cloud
https://linustechtips.com/topic/39899-corsair-c70-side-intake/
It will be eventually, but even if you have a dust filter it would be a problem. Just get some compressed air and clean your chassis every 6 months and you'll be fine
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/39899-corsair-c70-side-intake/#findComment-515060
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/39899-corsair-c70-side-intake/#findComment-515065
Ok thanks for the quick reply, I will go unfiltered and clean it now and again and get a filter if it becomes a problem.
Thanks everyone.
https://linustechtips.com/topic/39899-corsair-c70-side-intake/#findComment-515072
