Corsair Carbide Air 540 - Question
ExCaliBruh
Go to solution Solved by hooh888,
So Im starting my new build and got all my parts ordered. They should all be here by tomorrow or friday. Anyways the question is the magnetic fan filter for the Air 540. Is it mountable on the top as well? Cause the top fans have no stock filters on them, and I saw on the corsair website that they sell the magnetic front fan filter. Was wondering if it'll be a perfect fit on the top as well. Or should I just get other fan filters?
Just tried on mine.
The filter is too thick for the top panel to close properly.
Any recommendations for fan filters?
Thanks for the fast responses btw! I appreciate it
silverstone sells some 120/140mm fan filter mounts
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
http://www.amazon.com/gp/aw/d/B008N8GENI/ref=mp_s_a_1_6?qid=1435805693&sr=8-6π=AC_SX110_SY165_QL70&keywords=fan+filters&dpPl=1&dpID=41LmMyp5piL&ref=plSrch
Is this any good? I'm not the knowledgeable in regards to builds. Im just starting. So i apologize if I throw any dumb questions out there
that looks good, though i'm not aware about compatibility on top :( sorry m8
Silverstone has the best IMO, and the 2x 140mm fit nicley on top of the 540 and still fit under the mesh. You can also use ladies pantyhose for an effective and cheap fan filter.
Is this the fan filter youre talkin about?
--- My Rig ---
CPU : Intel Core i7 4790K | Motherboard : Asrock Z97 Extreme6 | CPU Cooler : Cooler Master Nepton 280L | RAM : 2x8GB Corsair Vengeance Pro DDR3PSU : Corsair AX860i |
GPU : Gigabyte GeForce GTX970 G1 Gaming | Chassis : Corsair Carbide Air 540 | SSD : Samsung 840 Evo 256GBHDD : Seagate NAS 2TB | HDD : Western Digital Caviar Red 4TB |
Optical Drive : Asus 24x DVD-RW | Lighting : NZXT Hue | Monitor : Dell U2515H | Keyboard : Ducky G2 Pro Blue Grey (Full Layout)Mouse : Razer Naga Chroma |
Mouse Mat : Corsair MM300 Anti-Fray Cloth Extended | Speakers : Altec Lansing Octane 7 | Headphones : Beyerdynamic Custom One Pro | Kingston HyperX Cloud II Pro
Primary mobile device : Galaxy S8 G950FD - Nova Launcher Prime | LG G Watch Urbane (Gold) | Secondary mobile device : PS Vita PCH-1000
that's what i would recommend too. I have my Power supply on my Air 540 filtered with one of these. Very easy to install and clean.
If would don't want to spent so much for the whole kit, they have the fitting single ones too.
http://www.demcifilter.com/p0432/Corsair-Air-540-Top-Dust-Filter.aspx
that's just the top filter.
Yeah there's no need to spend so much, just that my OCD wants me to cover up everything.  :P
That's perfect! Thank you!
No problem, been using it for quite awhile, and I must say all the provided dust filters does the job well, though some of them remained clean after half a year of usage. Mostly due to the positive air pressure that I've set up in my case, but at least when the PC is turned off I can sleep peacefully knowing the dust protection is still there lol.
--- My Rig ---
Demci ones, don't need to buy the whole pack, I would say top, and power supply for sure
