Problems with my 970
Go to solution Solved by blackadder,
Drop clock back to stock. Did you update drivers? Make sure igpu is disabled and power settings are correct.
I recently built myself a PC with (Evga GTX 970 acx 2.0 sc). And I still get bad fps in most games. I can't get the GPU clock speed apove 135MHZ. Whenever I try to make it go higher it goes to 900MHZ then back to 135!
Can somebody help me fix this problem?!
My gaming specs:-
Processor: Intel i5 4440
Ram: 8 Gb Hyper X
HD : 1 TB
GPU: EVGA GTX 970 acx 2.0 sc
MB : Gigabyte H97-D3H
PSU: Corsair CX750M
Note: http://imgur.com/JGPCG43 "this is a picture of my gpu state"
https://linustechtips.com/topic/397837-problems-with-my-970/
Do you have the latest drivers?
GAMING RIG:
CPU: i9-14900k
MOBO: Gigabyte Z790 Aorus Elite AX
RAM: 64GB G.Skill Ripjaws S5 @ 6000MHz
GPU: Gigabyte Gaming OC ICE 16GB 9070XT
STORAGE: Crucial 1TB NVME (Boot Drive) / 2TB Crucial NVME / 4TB 990 EVO Pro NVME SSD
CASE: Dimas Tech EasyBench V3.0
https://linustechtips.com/topic/397837-problems-with-my-970/#findComment-5363776
I didn't even know the GTX 970 can downclock that far....
Intel i5-4690K @ 3.8GHz || Gigabyte Z97X-SLI || 8GB G.Skill Ripjaws X 1600MHz || Asus GTX 760 2GB @ 1150 / 6400 || 128GB A-Data SX900 + 1TB Toshiba 7200RPM || Corsair RM650 || Fractal 3500W
https://linustechtips.com/topic/397837-problems-with-my-970/#findComment-5363870
Very strange
GAMING RIG:
CPU: i9-14900k
https://linustechtips.com/topic/397837-problems-with-my-970/#findComment-5363878
