As the title suggests, I need help with getting the airflow in my new rig case to be good.
I will post the specs of the rig if they are needed but I think they're irrelevant so I'm not posting them now.
Heres a sketch of how it kinda looks like in the case (beware, horrible MS Paint stuff):
Thanks in advance!
https://linustechtips.com/topic/397730-help-me-case-airflow/
Is the computer on carpeting? Also, the arrow should be facing the opposite direction for the PSU sense the main fan is for intake.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/397730-help-me-case-airflow/#findComment-5362408
Front fans intake rear fan exhaust. /thread :P Unless you have a AIO cpu cooler then exhaust out the top of the case intake stays the same.
MainRig- CPU: 4790k, RAM: 32gb 2400mhz, MOBO: Maximus Formula VII, COOLING: Full EK cooling, GPU: Titan X SLI, PSU: 1200w evga , STORAGE: 250gb SSD, 4TB hybrid CASE: 760T, EXTRAS: Sleeved cables
SecondRig- CPU:4690K, RAM: 16gb 1600mhz, MOBO: Maximus Gene VII, COOLING: H105, GPU: 970ftw, PSU: EVG650W,  STORAGE: 250gb SSD, 3TB, CASE: 540air
Steam: pizzatime6 Plus two other pc rigs and a craptop.
https://linustechtips.com/topic/397730-help-me-case-airflow/#findComment-5362425
Thanks for the quick replies!
I did the cable managment as best I could in regards that the PSU is not a modular one.
What I was wondering about is that once the GPU heats up it kind of just throws hot air upwards and also the hot air travels upwards too I believe, so I thought that front intake back exhaust wasn't gonna be sufficent.
And no, the case is not on a carpet it has its own place being lifted a few inches above the floor.
As I said, I apologize for the horrible sketch I just kind of did it as fast I could.
Thanks again!
https://linustechtips.com/topic/397730-help-me-case-airflow/#findComment-5362473
