Cable Sleeving
By
Vivilacqua1
in Cases and Mods
in Cases and Mods
Solved by W-L,
Hello! I have a question about cable sleeving. For 1/16" sleeving, would you use 1/8" heatshrink? Thanks for all your help!
It mainly depends if your doing heat shrink or heatshrinkless sleeving. Usually the minimum size you want is 1/4" 3:1 shrink ratio which I will compress the sleeve better.
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
