I have made a little cooling fan for my router cause it doesnt have one and it doesn't run at full speed. It is a 12V fan and USB only provides 5V. If i connected the 2 other wires from another 5V USB would it provide the an 10V therefore making it run faster?
ALCATRAZ |   CPU: i9 9900k @ 5GHz, Motherboard: Asus Prime Z390-A, RAM: Corsair Vengence LPX 32GB, GPU: Gigabyte 1070Ti Case: Zalman MS800 Plus, Storage: Corsair 2TB NVME | Crucial M550 128GB SSD  |  WD 640GB HDD, PSU: XFX Pro Series 1050w, Display: ASUS MG279Q, Cooling: Noctua NH-D15
https://linustechtips.com/topic/397568-usb-computer-fan/
You would have to connect it in series but I'm not sure how much the USB ports would like that If I recall correctly it would short out the 5V USB line so it's not a good idea. It would be better off to go with a wall adapter or use a buck boost to increase the voltage to the 12V you require.
Note most USB ports only supply around 0.5A.
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360044
The fan will run at 5V, even better as it will be very quiet. I'm pretty sure adding two 5v sources won't change the voltage. You will either gonna have to get a voltage booster or just run it at 5v
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360159
Dont. The USB's have the same source.
It would be like connecting it like this:
post-58487-0-65619900-1435696135_thumb.p
Please dont short out your router..
Get one of these instead, With this you can change the voltage to a balance where it isnt too loud and isnt too slow.
http://www.amazon.com/Universal-Power-Adapter-Output-1-5-3-4-5-6-7-5-9-12/dp/B00GO8LJ6Q/ref=sr_1_4?ie=UTF8&qid=1435696386&sr=8-4&keywords=ac+dc+variable+power+supply&pebp=1435696399337&perid=14B9X042QMPQ8V5AT45J
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360162
How could i change the voltage of the fan with connectors like those? Also the router is not connected at all to the fan. I have the fan seperate.
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360260
Did it by myself for summer... Doesn't look great but it
works... I used a normal USB cable, splitted it and used the red/black wires to power the fan.
What cable is connected to the four pin connector?
*Edit: I saw now :P But does it run very fast? Mine isnt blowing very much air.
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360288
You should not put different power supplies in series nontheless, One of the supplies will take all the load.
You just cut off the connectors or something, You are strapping a fan to your router so cutting off the cable 4-6cm from the connectors isnt very drastical.
You could just solder it back on if you regret it.
My Gaming PC
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360335
If you want the fan to run at full speed all the time this will be perfect:
http://www.amazon.com/Wall-Adapter-Power-Supply-12VDC/dp/B006GEPUYA
For a Buck boost that will let you cary vary the voltages or use the 5V USB line and boost it to 12V:
http://www.amazon.com/Switching-Regulator-Converter-Adjustable-Stabilizers/dp/B00BYTEHQO/ref=pd_sim_23_3?ie=UTF8&refRID=056GQ8PPZR9XWNC35HG5
Edited by W-L
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360353
That is exactly what i needed! And it looks like I also have one. Thanks mate!
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360538
Just double check with a multimeter since some of the non-regulated ones even though it says 12V runs at a higher range of ~13-16V.
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360561
Will do.
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5360565
Or you could use 2 USB ports to almost double the speed of the fan...
I dont have a 3 pin connector on the end. And im not sure which wire is red or black because the wires aren't colour coded. When i got it working first time i think it was luck Or something broke and now it is not working.
http://prntscr.com/7ngo34
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5365354
Just try until it spins! In a USB cable there's normally 3 or 4 cables: Data (normally green and white) and Power (red and black). Either it spins or not. (With some some fans it spins backwards if you get it wrong. Usually it doesn't work when the two cables touch each other. I used needles to solve this problem.
With photos:
post-239511-0-78571900-1435760043_thumb.
post-239511-0-98009700-1435760061_thumb.
post-239511-0-58403900-1435760074_thumb.
i7 6700k - 32GB DDR4-2133 - GTX 980
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5366510
  • 1 month later...
can you show us how you managed to attach 2 USB ports? can you explain it to for the noob?
Welcome to the Forums!
I highly don't recommend to connect it in series it shorts out the 5V USB power line with itself from the PSU, most boards have a short circuit protection circuit built in to make it work but it's not ideal. A better solution is to use a buck boost converter to raise the voltage.
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5732805
thank you :)
well I tried attaching 2 USB cables in series but the fan speed was still the same (slow)
plus I even tried single USB connection with my phone charger but still the fan speed was same :(
and I can't order/afford such converter in my country (Pakistan)
BTW I experimenting on Cooler Master Sickle Flow X (2000 RPM), I want it to run at full speed via USB :( for my laptop cooling solution
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5733768
-SNIP-
The buck boost converters aren't very expensive from Asia, but if you have 12V wall adapter that would work just as good and let you connect more fans than a USB port since most are only capable of 0.5-1Amp.
https://linustechtips.com/topic/397568-usb-computer-fan/#findComment-5733804
