Are you a Domain Administrator or Group Policy Creator Owner on the remote domain? Do you have RDP access to a machine in that network with the Group Policy Management snap-in or VPN access to the network so you can connect to the correct controllers from your network?
What exactly are you doing? Yesterday you were asking about cross-network remote registry... This would be easier if you explained what you're doing.
https://linustechtips.com/topic/397479-remote-group-policies/#findComment-5360123
Are you a Domain Administrator or Group Policy Creator Owner on the domain? Do you have RDP access to a machine in that network with the Group Policy Management snap-in or VPN access to the network so you can connect to the correct controllers from your network?
I am maintaining a computer, it keeps going wrong. I have been able to do the changes locally, so will not be needing this no more. I am using Team Viewer instead
https://linustechtips.com/topic/397479-remote-group-policies/#findComment-5360149
That's generally the easiest way to do it. Remote Registry is built in to Windows and you can remotely control Group Policy as well but it requires you to be on the same network either physically or using a VPN. It would be way to insecure to open those things up to the internet.
https://linustechtips.com/topic/397479-remote-group-policies/#findComment-5360286
