Hello!
Second time I'm on this thread in 3days... Things are going so well!
Jokes aside, I have a problem with my processor, well I think so.
Wen I got the processor, I installed in the computer, I saw that the clock speed, when in idle, was never over 2ghz, it was never at the 3.4ghz clock as said on the box, since it's in idle, it's pretty normal I guess, it doesn't need that extra clock speed to run an internet browser (because of power saving), and I had temps of around 30° celsius. Now since last week, the clock doesn't want to go under my oc setting (3.8ghz) when in idle, it just stays at 3.8ghz and wich makes it have temps of around 40° celsius in idle, and I have a CM Hyper 212 Evo with 2 Thermalright fans on it, wich should normaly make it run at around 25°-30°, wich it doesn't.
So what the hell is going on ? Should I send it back ?
Help :(
Thanks in advance for your answers!
EDIT: Go see the last post, it's my latest problem!
VIDEO GAMES                                  Max Power Build Log
https://linustechtips.com/topic/39695-i5-4670k-clock-problem/
I don't know for sure as I have never overclocked but I have read a bit about it and i believe to overclock your cpu is set to that frequency and doesn't down clock for idle, if I am wrong then there is probably a setting to enable/disable which allows itself to lower the voltage and down clock other than that I can't think of a reason it shouldn't
My Current Rig: CPU: i7 4790k @ 4.8Ghz CPU Cooler: H100i MOBO: Gigabyte Z97X SOC GPU: XFX Radeon HD 7950 Tahiti pro (Died 6/07/2014 RIP) & PowerColour HD7950  GPU Cooler: NZXT G10 W/ Corsair H55 HDD&SSD: Seagate Barracuda 1TB + Corsair GS 128GB + Samsung 840 EVO 250GB PSU: Corsair RM 750 Case: Fractal Design Arc Midi R2.
https://linustechtips.com/topic/39695-i5-4670k-clock-problem/#findComment-512380
I'm pretty certain that's normal. When overclocking, the processor stays at the set clock speed, so assuming I OCed to 4Ghz, that's what I'd stay at, even if I was just moving around my cursor on my desktop.
That being said, I'm not 100% sure, I'd look it up, but I wouldn't worry about it not dipping down. If you're still nervous about it, just set it back to stock.
https://linustechtips.com/topic/39695-i5-4670k-clock-problem/#findComment-512416
Hello!
Help :(
So what's your problem? not having it downclock on idle or having temps at 40 Celsius? if it's the temps, they could be normal depending on ambient temps, try re applying the thermal paste maybe?
as for the not downclocking part, make sure all your C states are enabled, phase control is on adaptive and check your voltage, if it's on a manual some motherboards won't let your processor downclock either.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/39695-i5-4670k-clock-problem/#findComment-512460
Ok I just saw something strange when I updated the bios to 1.2 on my MSI Z87 MPower Max, I have now 2 DRAM frequencies setting, I had 1 before, and my ram doesn't clock at 1600 like it should do, but it just stays at 1333...
WTH is going on with my system :(
https://linustechtips.com/topic/39695-i5-4670k-clock-problem/#findComment-519091
post a ss with cpuz memory tab open also post another with cpuz spd tab opened
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/39695-i5-4670k-clock-problem/#findComment-519151
Hello!
Help :(
dont send it back, its not faulty its just dynamically lower its speed to save power and be quieter, once you oc itll stop doing that.  I dont see what your problem is with the cpu. The memory issues is weird, in your frequency settings in your bios for the memory take manual control of the timing and multiplier, make sure your bus speed is stock 100.  Can you rephrase your problem? Just seems like you don't know whats going on.
https://linustechtips.com/topic/39695-i5-4670k-clock-problem/#findComment-519196
