Pro Tools Help
Solved by johnny5c,
I need to reinstall windows 7 on my computer (I don't need to, but I want to so I can start fresh again). Anyway, I have pro tools express but it requires an iLok to use, but it's a one time install. Can I put in on my computer again once I reinstall windows, or will that not be possible? Any help is greatly appreciated.
Yes you can, if you don't have the activation code card you can login to your Avid account and get it from there and you'll also need your iLok ID..
