Plugging Fan Splitters into Fan Splitters
Go to solution Solved by Rovert19,
Perhaps something like this would be useful.
http://www.swiftech.com/8-waypwmsplitter.aspx
Is it safe to plug fan splitters into other fan splitters? I was planning to use an ITX motherboard for my build, and those dont have many fan headers most of the time, so I was going to buy 2x 4 fan PWN splitter and plug those into each other. The splitters I am going to be buying have MOLEX 4 pin connectors to provide more power. http://www.frozencpu.com/products/14982/cab-627/EK_4-Pin_PWM_4-Way_Splitter_Cable_-_Sleeved_Black_Black.html?id=KppXD7AX&mv_pc=18547
One end plugs into the 4 pin motherboard connector, and one end plugs into a molex connector.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/39668-plugging-fan-splitters-into-fan-splitters/
i do this :D ya its fine. one thing i noticed is my super cheap case fan (the included with the case one) needed some power. it was on the last end of the daisy chain and wouldnt spin so i hooked it to the mobo.
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
Do you think this is because of the daisy chaining or because it does not support PWM?
There are PCB fan splitters with 4pin connectors, and you plug in 2 molex connectors to the PCB to power it. Can you control those PWM fans? http://www.frozencpu.com/products/7614/bus-141/Bitspower_X-Station_Power_Extension_II_-_UV_LED_BP-XSP2M-UV.html?tl=c17s424b145&id=KppXD7AX&mv_pc=19012
definitely daisychain. ive had it hooked to a splitter before but the dasiychain killed the power draw. i pump as little power into my fans as possible. remember, the more cables you have the less effective a connection becomes.
I understand resistivity but, you must have been running your fans pretty low to not be able to start the fan up.
@WunderWaffle the PCB you linked to runs 12 3 pin headers (No PWM) but at 3 different voltages: 4 at 12v, 4 at 7v and 4 at 5v
It also has 8 4 pin ports.
EDIT: OOOOOOh. it has 8 MOLEX connectors... Woops...
Do you know the pin-out of 4 pins?
12v ground ground 5v
With this you could achieve 12,7, or 5 V without any need for a pot/resistor to tweak it.
No, that does not support PWM but, yes it does support running fans at multiple speeds.
Yeah... i edited my post. Sorry.
No need  ;)
Honestly, if I were you I would go with the first thing you linked to. Might require some tweaking but it should work...
I am not sure about the problems whatthe_fuzz was experiencing. At the length and quality of the wires the splitters should be using the extra daisy chains should add very little resistance.
I think the fan he was using was probably low quality and did not behave well to undervolting.
Seeing the quality of the other components in your build you probably wont experience this your fans but it is worth looking at reviews to make sure the fans you get do support it.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
Arc Midi R2 | Asus Maximus VII Hero | Intel i5 4690k | Asus GTX 970 Strix | Corsair H80 | Crucial M4 128gb | 8gb 1333 Mushkin Silverline | EVGA G2 750
Filko Ninja TKL Cherry MX Black | Mionix Naos | Fiio e10k | Edifier S330D | Sennheiser HD558 | Blue Snowball | Asus PA238QR | Samsung BX2250
Love it. Marked you solved, going to buy that.
Glad I could help.
