Best mid tower for a custom loop?
Go to solution Solved by X_Rated_Box,
Hey :D welcome to the forums
The s340 would be neat but it is pretty small and it was relatively hard for me to put an AIO in there so it wouldnt be the best for WC but have you thought about the Define series by Fractal Design it is perfect for watercooling (especially the Define S)
But i dont know if it is too big for you:D
(question what monitor do you use it looks dope!):D
Hello!
I have been interested in doing a custom water loop for quite some time now,
However I have always loved somewhat smaller cases. (My current case is the Corsair Air 240)
I am willing to get a slightly larger (mid tower) to allow for an easier time doing my first water loop as I think I would struggle too much attempting to do one in a mATX form factor.
I have seen the S340 which looks like it might be smallish but also have a good amount of space for a loop.
I will most likely be building using parts from my current PC (https://au.pcpartpicker.com/b/f2TH99) and eventually adding in a second 970 in SLI.
I'd also quite like a side window, and nothing too "gamer" looking I guess, something minimal and stylish is probably more what im looking for.
Any good tips or advice for this magical case I am in search of?
:D
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/396462-best-mid-tower-for-a-custom-loop/
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
Hey thanks for the warm welcome and advice!
Yeah I do know the Fractal Define cases, they are really nice, might look into them some more :)
(question what monitor do you use it looks dope!) :D
I have a BenQ VZ2350HM 23" IPS monitor and love it, the only somewhat issue with it was when it was advertised they had the picture right to the bezel instead of about 10mm of black line around the edges.
The S340 is small but it has terrible rad support. I'd get the H440 or Define S/R4/R5
Just did further research into the Define S and I think I am sold!
Seems to be exactly the type of case I was looking for, thanks! :)
My Rigs:
Case:
Case:
Please link me under your future build log :D seem like an awsome build :D
Glad i could help you :D
"The S340 is small but it has terrible rad support"
Nah I think the possibilities are great actually it has got room for 1x 280/40 2x120 I wouldnt call this terrible especially for that size:D
Okay, front for 240mm but that's about it. I can't believe they only did a single in the top..
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
Yeah (Its 280 but nvm:D) and yeah the possibilities are there but they havent done it :D
