So my Xbox 360 has gotten the RROD, I can get it fixed but I want to replace the heatsink and want to purchase the Zalman CNPS5X Performa CPU Cooler. I'm just not sure if it will fit in the 360 socket. I have no idea what type of socket it but i do know that the mounting holes measure 60mm x 60mm. Does anyone know if the cooler will fit?
BTW if this is in the wrong forum, I'm sorry.
https://linustechtips.com/topic/396325-rrod-help/
Not likely. I can't think of any socketed CPU that has mounting holes that close together. Maybe you'll have better luck with one of those universal GPU coolers
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
https://linustechtips.com/topic/396325-rrod-help/#findComment-5346105
Doesn't the red ring happen because some adhesive or something ends up melting? But yeah I don't know of any cooler that would fit the 360's mounting holes. You should make a custom one with your neighbor's CNC!  ;)
CPUAMD FX 8320 @4.4 GHz 1.212 vcore Motherboard - Asus M5A99X R2.0 RAM - G.Skill Ripjaws X 16 GB 1866 GPU - Asus Gtx 970 Case - Corsair Vengeance C70 Military Green Storage - 120 GB Samsung 840 Series, 1TB WD Black,  240 GB Corsair Force LX PSU - EVGA 750W G2 Cooling - Noctua NH-D14 Keyboard Corsair K70  Mouse - Logitech G502
https://linustechtips.com/topic/396325-rrod-help/#findComment-5347854
