So I need your guy's help finding an old build log that I'm sure I saw on this forum
It was a guys LAN rig, and he even had a few pics of it at a LAN. It featured an mATX Asus motherboard, a closed loop liquid cooled CPU, the motherboard was oriented with the I/O facing upwards, and the entire chassis was hand-made out of aluminum. I also (oddly enough) remember that he had a fan controller that was just sort of placed towards the bottom of the unit, and he mentioned that he wanted to find a more ideal place for it. I think it might have also been a featured build log on a WAN show, but I can't quite remember if that's how I found it.
The reason I'm looking for it is that it used a hand-made motherboard shroud, and I'm looking to do something similar for an upcoming build, and wanted to show it to my metal-working buddy so he can get an idea of what I'm looking for.
I also think it had a girl's name, like Elise or something along those lines.
I've been searching for the last few weeks for this build log, but to no avail. My Google-Fu has failed me.
Please help me guys!
Edit: Nevermind guys, in a moment of either pure genius or luck I seem to have found it again. For those who were curious, here's a link.
Carry on!
My Build
i7-4790k @4.6GHz, 16GB GSkill Ares RAM, Gigabyte Z97X-Gaming G1, Strix 970, RM1000 PSU, 128GB Sandisk SSD, 1TB Barracuda, 3TB WD Green, CM Storm Scout II
https://linustechtips.com/topic/396213-help-finding-old-build-log/
Use the search function on the forum and use the name that you think are correct, that is all that i can help you with
I can assure you I've tried it many times, with many different combinations of remembered information.
My Build
