Problems turning off my pc
Go to solution Solved by Cyrus49,
Hi there, I recently got a new computer and after a while decided to add a sound card.
After adding that the computer then decided then that upon hitting the power off (on the windows interface anyway) on occasion it would turn off and then a few seconds later would turn on.
Would to know what might cause it and if there is a fix I would like to know as well :)
Many thanks in advance!!
Go into command prompt and type : powercfg -devicequery wake_armed
Then go into device manager, right click on those devices, go to the power management tab, then unclick "allow this device to wake the computer"
I hope this helps :)
https://linustechtips.com/topic/396023-problems-turning-off-my-pc/
Happy to help with any tech problems. Windows 10 installing guide here.
----i5 4570s----gigabyte z97x-sli----8gb ddr3----gigabyte g1 gaming 960----HAF 912----120gb ssd----1tb hdd----500w evga----
Tried, hope it helps :) odd thing is that my keyboard I have a hard time to believe is sending any commands after power off (and it started before I got this particular keyboard) perhaps the mouse somehow hijacks just before power off? (it is rather sensitive :))
Or maybe some sort of packet reaches my NIC just before it turns off :)
anyway, thanks! will let know if it doesn't help :) otherwise many thanks!
No problem!
