Hey guys. I was wondering if anyone can recommend a desktop wireless card for my gaming rig. I can't take time off of work for a couple months and I'm in the process of building my system. Is it worth it to look for a wireless card, or should I wait to try to get a tech to come to my house and fix the wiring for this outlet? I have a MSI Z97 gaming mobo at the moment. Thanks in advance.
https://linustechtips.com/topic/395842-a-wireless-network-card/
Ethernet is allways better than wireless.
But when the tech is very expensive and / or you have to wait long, you can buy a wireless card.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/395842-a-wireless-network-card/#findComment-5340127
I use this TP-Link and, during good hours of the day, I get ethernet speeds. So wireless isn't always a failure.
https://linustechtips.com/topic/395842-a-wireless-network-card/#findComment-5340197
I'm not sure how much they would charge to bring out a tech, I assume around $50 to $100, but it'll be a while before my build is complete anyway. Mine as well save up for that also and get another router for this room I guess.
Dang thats like daylight robbery right there :o jk :) Thats expensive for the plug though. All you need is a wiring diagram and the tools and you can do it yourself :)
I'd go with the ethernet cable, because then if anythings wrong, you can know its either with the router or the wire.
https://linustechtips.com/topic/395842-a-wireless-network-card/#findComment-5340212
I use the same card and get 50mb/s down 25mb/s up which is exactly what we pay for  :D and I'm on the other side of the house as the router :3
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/395842-a-wireless-network-card/#findComment-5340213
A wireless card will be cheaper, but a finctional wireing will add value to the room.
EDIT: But the card will add value to the PC ;)
https://linustechtips.com/topic/395842-a-wireless-network-card/#findComment-5340216
Yeah, I have comcast. When I got the service, they tried to charge me for having a tech to fix the wires that the previous tech was supposed to fix but didn't. I want to say they tacked like a $50 charge on my bill for it, but took it off when I tlaked to them about it.
https://linustechtips.com/topic/395842-a-wireless-network-card/#findComment-5340290
