hello guys
MY PC IS WINDOWS 8.1 PRO
i had a very hard day my pc has crashed showing error (THE BOOT CONFIGURATION data for your pc is missing or contain error) and i can't boot to desktop
then i had error 0xc0000034 then error 0xc000000f
OK Now i fix them all and i don't know how i did that ! ok now i have a problem and i need your help now when i boot in my pc i can't change account or change pc setting and all the icon are missing in the start menu plz guys help i want my pc go back to normall plz help
https://linustechtips.com/topic/395565-please-help/
unplug your drive(s) and plug them back in
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/395565-please-help/#findComment-5336735
nothing happens :(
According to Microsoft:
Method 1: Booting to Recovery Environment with Windows 8 installation media.
Please follow the steps given below. Insert the Windows 8 installation DVD in the DVD ROM and restart your computer.
a) After you boot your computer using Windows 8 DVD or System Repair Disc, a black screen appears with gray text "Press any key to boot from CD or DVD". Press any key.
b) Select the correct time and Keyboard type.
c) Click Repair your computer in the lower left corner.
d) Select Troubleshoot from Choose an option screen.
e) Click Advanced options in Troubleshoot screen.
f) Click Automatic Repair from Advanced Options screen.
g) Next, choose the operating system by clicking on its button.
h) Windows 8 will look for problems on hard drive(s) and verify that all required files are intact.
Method 2: If automatic repair doesn’t help to repair the startup files, you may try to repair them using these commands through Command Prompt under Advance Options.
Refer to the steps:
f) Click on command Prompt.
g) Type these following commands and hit enter after each line of command:
Bootrec /fixmbr
Bootrec /fixboot
Bootrec /scanos
Bootrec /rebuildbcd
https://linustechtips.com/topic/395565-please-help/#findComment-5336810
I will try cheeze way see if it work but now i need to sleep i didn't sleep all night
ok if i re-install windows without losing my files i need to install all my programs again ?
i just wanna tells u that my programs installed in drive D not in drive C that has a windows
Yep. if you make sure when you reinstall it not to write over the drive.
https://linustechtips.com/topic/395565-please-help/#findComment-5342947
