I currently have an Arctic Freezer 7 Pro Rev 2 on my i3 4360. I was wondering if it were possible to run this cooler passively and have something not explode. I use a Cooler Master Sleeve bearing 120MM at the back of my case and a Noctua P12 120MM on the front, both running at super low speeds. I use an EVGA 550W GS and my Asus 7770GHz fan does not come on until 60C. Trying to pursue a totally silent system in case this was not obvious enough.
Thanks.
TL;DR: Arctic Freezer 7 Pro Rev 2 passive on an i3 4360??
https://linustechtips.com/topic/394823-passive-cooling-my-i3/
Thanks.
Nope, I've got one of those coolers, and the damn thing is pathetic with the fan.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327406
What motherboard? My MSI motherboard cant set my NF-P12 to 0RPM but it can make it run low enough to report 0RPM and be silent. You'll probably have to undervolt the CPU too.
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327415
Thanks.
If you undervolt it then maybe.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327421
It's not the best cooler in the world, I know.
Gigabyte B85M - DS3H
How does one go about doing that? Aren't voltages locked on non-K Intel chips?
Huehuehue
No.
With the fan works ok.
I've it on my R7 250 and i tried once unpluggin the fan. 99 C
Cheers
How does on simply put it on a GPU xD
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327444
The multiplier is locked, I don't think the voltage is.
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327448
OK, I'll look into it when I get access to my PC on Sunday.
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327452
I'll put it this way, the $31 Coolermaster Eclipse is better (LGA775 BTW) than the Freezer Pro 7 Rev 2.0, which for me cost $27 and is only a tad quieter than the stock Intel cooler that came with my i5 4440 for the same performance.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327505
Undervolting is always the key to passive cooling. I've shaven 26C off one of my CPUs with a good undervolt, but let me stress: Contrary to common belief, undervolting does not necessarily entail underclocking!
For the record, I'm running a passively cooled i7-5930K at stock clock and 0.925V.
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327511
You know what? I'd do that if I could mount it to the back of a graphics card.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327514
Yeah, I felt like I should've got something different. I got mine for $19 though, I was just on a tight budget looking for a quiet cooler and it seemed like a good option.
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327515
It kind of is, but you can get better coolers for less or significantly better for just a little bit more. Even going second hand would be no loss, just a quick clean, maybe a new fan and your good to go. BTW, I asked the same question about using the FPrev2.0 passively-and later on when I tested it: 'Well, I hope that smell isn't the i5 frying'.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327667
Well I guess we won't be trying folks! xD
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5327693
It wasn't-a few seconds later the computer shutdown because the CPU temp was too high, and the 250W PSU died on me-it was mounted in the top of the case and sucking all of the heat from the CPU.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/394823-passive-cooling-my-i3/#findComment-5328355
