Cheapest way to display to 2 monitor.
omaroma11
What is the cheapest way to display to two Dvi monitors from a Chromebook pixel.
"You can connect the Chromebook Pixel to an external monitor with a Mini DisplayPort-to-DVI or Mini DisplayPort-to-VGA adapter. Connecting the Chromebook Pixel to multiple external monitors isn't supported at this time. Connecting the Chromebook Pixel to multiple external monitors isn't supported at this time."
http://liliputing.com/2012/11/google-brings-dual-monitor-extended-desktop-support-to-chrome-os.html
you can do one
not 2
I see. But you would have two displays including your laptop.
true
