Hey guys so....this is going to be my first build i do on my own and i would like your opinion on this.im going to be useing onboard graphics for a bit and then gona take the new gpu
https://linustechtips.com/topic/394253-my-first-build-halpp/
-snip-
Alright, looks fine.
But you should tell use the purpose and budget of the build and use http://pcpartpicker.com/
https://linustechtips.com/topic/394253-my-first-build-halpp/#findComment-5319907
i live in greece and im going to buy from local retailers and its gona be gaming and my dad gona use it for some work i want to know if this build is ok well my buget now is 430E without the gpu and dont send any apu stuff
Well this looks fine, but I don't know that much about motherboards so I wouldn't know if that motherboard needs a BIOS update or not..
https://linustechtips.com/topic/394253-my-first-build-halpp/#findComment-5319942
then how about
Thermaltake Munich 430W
i heard good stuff from some friend of mine
It sounds like your friend is trying to blow up your build . . . jk but don't buy it. The one you have now is decent. I owned a corsair psu in the past and it was good. You shouldn't have any problems with it. One other thing, your gpu is red and the rest of your build is blue, if you care for color matching. Just saying, because i had a blue build and got red ram. I have since pryed off the ram heatsinks to reveal the nice black pcb, but I was just wondering.
Don't Drop the Soap
https://linustechtips.com/topic/394253-my-first-build-halpp/#findComment-5320353
well if i had a windowed case i would have a problem but with that case i dont think so
https://linustechtips.com/topic/394253-my-first-build-halpp/#findComment-5323502
