whats your budget? I would get a beefier PSU and an SSD. Also, get a Be Quiet! Pure Rock CPU cooler.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/394011-first-build/#findComment-5316920
Do you already own the GTX 770?
Build: CPU: i7-4790k @4.4 GHz 1.2v | GPU: Sapphire R9 380 Nitro | Memory: 16GB Evga SSC | Storage: 250GB 850 Evo, 1 TB Toshiba HDD | Mobo: Gigabyte GA-Z97X-Gaming 7  | Cooling: Aigo T120 RGB | Case: NZXT S340 | PSU: Antec HCG 520w | OS: Windows 10 | Keyboard: Corsair K70, Cherry MX Reds | Mouse: Logitech G600 | Monitor: LG 27UD58-B | Headset: Audio-Technica M40x w/ Modmic and Bravo Audio V2 Tube Amplifier
https://linustechtips.com/topic/394011-first-build/#findComment-5316929
770 seems like a bad choice. If you are on tight budget get something like gtx960 or r9 290.
CPU i7 4770k GPU GTX980 MOTHERBOARD Asus Maximus Gene VII RAM Hyperx Savage 2x8gb STORAGE Crucial m550 512gb PSU Corsair AX760 COOLING Corsair H80i GT CASE Corsair 350D OS Windows 10 64bit KEYBOARD Logitech k810 MOUSE Logitech Performance MX
https://linustechtips.com/topic/394011-first-build/#findComment-5316953
no i do not ow one
If so, instead get a r9 280x or 290. These are both great performing cards for their price point.
https://linustechtips.com/topic/394011-first-build/#findComment-5316966
I would go with some high speed RAM, your motherboard has great potential, I would utilize more of it's capabilities. May not do you much more good for games, but when you start to do other functions and start utilizing more background programs the extra speed in the RAM can greatly help the processor, especially in programs like Chrome when you use multiple tabs.
AMD Ryzen 5 3600, ASUS B350-F Gaming, Trident Z RGB 3200MHz 16GB, PowerColor Red Devil 5600 XT, NZXT H500, 1x512GB Seagate Barracuda NVMe, 2x2TB Firecuda 7200RPM, 1x250GB Intel SSD (Cache), 1x4TB Seagate 7200RPM Ironwolf (Backup), 650w EVGA Bronze
https://linustechtips.com/topic/394011-first-build/#findComment-5317026
Just no..
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/394011-first-build/#findComment-5317090
http://pcpartpicker.com/p/QJc83C
What do you guys think? If you have any suggestions, tips or things like that please tell me.
Unless you have that GPU or are getting one used for $70.. your not going to have a gpu..
For a $700 build all in with new parts, this is about as good as you can go.. (allows sli, possible drop in upgrade to unlocked cpu for oc later)
You could shave a bit off here and there and try get a better gpu.. but it's a choice of 960 or 380x at this budget.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($166.95 @ SuperBiiz)
Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard  ($94.99 @ Micro Center)
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1600 Memory  ($43.99 @ Newegg)
Storage: OCZ ARC 100 120GB 2.5" Solid State Drive  ($53.99 @ Amazon)
Video Card: MSI GeForce GTX 960 2GB Video Card  ($192.49 @ SuperBiiz)
Case: Fractal Design Core 2300 ATX Mid Tower Case  ($44.99 @ Directron)
Total: $697.38
Generated by PCPartPicker 2015-06-25 20:06 EDT-0400
Total: $697.38
https://linustechtips.com/topic/394011-first-build/#findComment-5317143
