ok then i got my hands on a 48 port switch, FOR FREE :D i got it because it was never going to be used fsr and no its not broken it works just fine just that someone has put a password on it and limited some ports to ongly 10mb/s so first off i need to get rid of that password, so i found a manual stating that you can reset evrything by just using reset as your password and username but do i need to remove this? also the IO on the back, what needs to be plugged in and what is optional?
the switch is a 3Com SuperStack-3 3250 if anyone cares
post-227720-0-32337900-1435246133_thumb.
post-227720-0-54047000-1435246166_thumb.
Builds:
https://linustechtips.com/topic/393808-switch-help/
Best to reset the password
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/393808-switch-help/#findComment-5314466
found the manual http://h20565.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c02584130
Just plug in the power and then it will work, the other stuff is optional
https://linustechtips.com/topic/393808-switch-help/#findComment-5314481
ok thank you
Builds:
https://linustechtips.com/topic/393808-switch-help/#findComment-5314505
ok thank you
np u need to get rid of that 10mb restriction lmao
https://linustechtips.com/topic/393808-switch-help/#findComment-5314509
well fuck, it wont connect to the network, any ideas? i have my router conected to my swich and then the switch to my PC, i also tryed without the router and that didnt work either... :(
Builds:
https://linustechtips.com/topic/393808-switch-help/#findComment-5315050
It will probably take 10 min to boot up. Make sure its connected via the uplink port, try both. Then scan ur network for a list of ips taken and what the addresses are, there r some free phone apps that do this.
https://linustechtips.com/topic/393808-switch-help/#findComment-5315325
well i can connect butn i get "no network acces"..
Builds:
https://linustechtips.com/topic/393808-switch-help/#findComment-5315400
U need to find its ip on the network and go to its ip in ur browser to login
https://linustechtips.com/topic/393808-switch-help/#findComment-5315430
blank page :(
Builds:
https://linustechtips.com/topic/393808-switch-help/#findComment-5315448
blank page :(
U need a hard reset of the switch, or try some other browsers.
https://linustechtips.com/topic/393808-switch-help/#findComment-5315451
blank page :(
to reset the switch you will need a Serial COM port  and a serial cable (DB9 connector at each end) For this particular one you will requre a Null Modem Cable. You can then use Putty to connect over serial to get to the switches command line.
On putty you use these settings: auto-baud, 8 data bits, no parity and 1 stop bit.
Then you can log in to the switch using "recover" as the username and password to reset its login details.
Default login is admin, no password
The getting started guid for the switch: http://h10032.www1.hp.com/ctg/Manual/c02583441
https://linustechtips.com/topic/393808-switch-help/#findComment-5315833
Looks like any RS232 cable should work. Doesn't necessarily have to be a null-modem cable. That's just from a cursory look on my end though.
@OP: You're probably in over your head, to be honest. There's no reason you need a 48 port managed switch--especially if you don't know how to configure it. It draws a lot of power, and is unnecessarily loud. Trust me--I use them daily.
--Neil Hanlon
Operations Engineer
https://linustechtips.com/topic/393808-switch-help/#findComment-5317439
shite.... well the LAN i was going to use the switch for was yesterday and now im really sick and tired... wish i had seen this earlyer so i could have done something
it sounds like a fucking jet and i just want it because it was free and im tired of desktop switches like the ones i used for the LAN i did the networking and stuff for, now im going to sleep some more
Builds:
https://linustechtips.com/topic/393808-switch-help/#findComment-5330747
