So hey guys usually I know my stuff for this but a friend is asking for a good usb condenser mic that they can hook up to pc.
Now before you all start saying look at linus videos that he posted, which I have watched this one wont be used for gaming/ skype the usual.  This is for Singing and not sure what to go on from this.  I know two good ones will are blue yeti, the rode ntsb,, at 2020usb, and the blue snowball(don't think it will be good or not).
She is used to the shure pg42usb which is not in her budget so yea....
Can you all give me reasons of which one you would choose and the reason for it, I will be passing it on to her.
Thanks  guys
https://linustechtips.com/topic/393537-usb-microphone-help/
