So Im running Windows 10  Preview with an activated 8.1 pro key
on An Asus G751JT Laptop
The Issue I am haveing is that I am unable to connect to My home wifi
At work I am able to connect just fine via there guest wifi  and the same goes for at school No issue
as soon as I get home MY wifi spools up and says unable to connect from a range of less then 2 feet from the router
it connects fine wired just not wireless and yes its turned on.
Does any one have any ideas other then it being a windows 10 issue.
https://linustechtips.com/topic/393434-odd-wireless-issue/
Did you reboot the router? Do you have a USB dongle you can try?
https://linustechtips.com/topic/393434-odd-wireless-issue/#findComment-5309077
It connects wireless just fine everywhere but my home also all my other wireless devices are working just fine. And I tryed both a dongle, wired and witlessly plus I uninstalled and reinstalled my drivers.
https://linustechtips.com/topic/393434-odd-wireless-issue/#findComment-5309110
I don't want to go to Windows 10 even if I get it for free.
I like the layout of the OS but its not ready yet and I knew that going in but I had a fresh PC and thought I would play with it a bit thinking that I could work around the bugs until they got sorted.
https://linustechtips.com/topic/393434-odd-wireless-issue/#findComment-5309198
