tinanic power
Solved by refhat21,
According to nvidia website titan x need 8 gb minimum 16 gb recommend.can someone explain to me why the titan x min requirements is 24gb memmory??
MINIMUM SYSTEM REQUIREMENTS:
PCI Express-compliant motherboard with one dual-width x16 graphics slot
One 6-pin and one 8-pin PCI Express supplementary power connector
Minimum 600 W or greater power supply
300 MB of available hard drive space
8 GB system memory (16 GB or higher recommended)
Microsoft Windows 8 and 8.1, Windows 7 or Windows Vista
