I have adblock, so obviously I don't get ads on anything, but just recently I have started getting these weird pop up things that say "ads by anti adblock" and I'm 99% sure it's a virus. I have microsoft security essentials and when I do a scan, it says my PC is fine. So does anyone have any suggestions as to how I can fix this?
When I google things it does this:
http://gyazo.com/bd08816fdb0253f876a02c6487f6b5c4
And sometimes it will pop up with a white screen that says "Ads by anti adblock" but I can't seem to replicate that right now.
EDIT:
It did it just as I posted this:
http://gyazo.com/736bca0b90fd6e4205c41973ed0b41db
Thanks!
https://linustechtips.com/topic/393121-possible-virus-help/
look into your recent installations and search for software you haven't installed
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/393121-possible-virus-help/#findComment-5305265
EDIT:
Thanks!
Try Malwarebytes
https://linustechtips.com/topic/393121-possible-virus-help/#findComment-5305324
Try Malwarebytes
Malwarebytes identified a few threats, and deleted them, but none of which seemed to fix the problem.
However, I went into my Chrome extensions after and found that there was one that I never downloaded, or at least know about downloading.
I've had this happen before where a Chrome extension would just appear, I'd delete it and it would come back. So when this problem with these "Anti adblock" things started coming up I continuously checked my extensions but there were only the ones I wanted.
So how can I stop these extensions from just coming up randomly despite being deleted?
https://linustechtips.com/topic/393121-possible-virus-help/#findComment-5315112
Try resetting your chrome settings. It'll delete everything. So backup your files.
https://linustechtips.com/topic/393121-possible-virus-help/#findComment-5315535
