I need help fast
Solved by PaulK,
All I can think at this point is:
1. corupted system file (maybe explorer.exe) You can use sfc /scannow from command promp with elevated privileges click on start -> type cmd -> right click on cmd and click on run as administrator
2. corupted registry You can try an restore registry from a previous version backup
3. corupted user account. Restart your computer in Safe mode and login with administrator account and see if the problem persists. If the folders show up in main window create another user account and see if after restart (normal mode) this problem is solved.
Try no 3 first
PS - did you notice that there's no clomun header? It should be there if you select to view details...
