Rust has early access issues.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/392865-huge-stutter-issue/#findComment-5301892
Answer those:
What resolution are you running?
What CPU utilization do you have?
What graphical settings?
V-sync on?
That CPU is tanking the GPU btw.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/392865-huge-stutter-issue/#findComment-5301894
Do a full reinstall of your drivers, reinstall DirectX, clean your registry, defrag your drives
Also, the 6300 isn't bottlenecking the GPU
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/392865-huge-stutter-issue/#findComment-5301904
1080p
what is that?
high-very high
v-sync off
what do u mean by tanking?
How much the CPU is used in %? Latest drivers?
https://linustechtips.com/topic/392865-huge-stutter-issue/#findComment-5301907
which version of direct x? and what is registry
https://support.microsoft.com/en-us/kb/179113follow instructions here for DirectX
https://www.piriform.com/ccleanerdownload and install this and follow the instructions on their site
https://linustechtips.com/topic/392865-huge-stutter-issue/#findComment-5302122
