if i use a XFX Radeon r9 280x with a AMD FX-8350, will it basically suffer frame drops or any other trouble while gaming??? ima use this build im planning for music production, photo editing, and gaming at 1080p 60 fps. i heard alot of things about AMD not being good for gaming but for editing and all that, the programs can use the extra cores?? im a noob at this and well i need some help !!
https://linustechtips.com/topic/392845-help-budgetbuild/
The 8350 may be a bottleneck in gaming, but the 8 cores will be better than a basic i5 in video rendering.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/392845-help-budgetbuild/#findComment-5301579
Have you suffered any problems? with major games like gta 5, battefield 4? ETC ?
GTA V and Battlefield 4 are both quite demanding on CPU. Fortunately, both of them also scale quite well with core count. It may be worth checking out these CPU benchmarks for those games:
http://www.techspot.com/review/991-gta-5-pc-benchmarks/page6.html
http://www.techspot.com/review/734-battlefield-4-benchmarks/page6.html
Your performance should be fine.
i7-5820K | GTX 980 Ti
https://linustechtips.com/topic/392845-help-budgetbuild/#findComment-5301612
GTA V yes, but not just bugs in the game in general.
Also update graphical driver to the latest, because some games bug up lots with older drivers.
https://linustechtips.com/topic/392845-help-budgetbuild/#findComment-5301614
It depends on the games you play, If the games you play make use of 5+ cores you should be alright.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/392845-help-budgetbuild/#findComment-5301728
