Dac/Amp for DT770 250ohm
Aristos
Hello,
I would like your advice on a dac/amp to get the most out of my Dt770 250ohm headphones.
Right now I have them plugged directly into the front panel jack but they do not sound as clear as I would like especially on low volume.
My budget is 200 euros max.
P.s I don't know much about audio, dacs or amps
Well of course they don't sound as clear on low volume; that's what happens when you turn the volume down. You could always try the rear motherboard jack, or if you like spending money, get a Fiio E10K, Schiit Fulla, or SMSL SD793-II.
