Lighting effects for my modding plan?
Solved by cravinmild,
UV Green (tubes) is pretty bright from what ive seen. I use white UV tubes and it lights the whole desktop up, ended up removing one because of it. I love case lighting ... any lighting really. The tube lighting like mine can come in different lengths, longer tubes equal more light. Those cheapy LED lights can illuminate an area of the case without having it lighting the whole case up. I bought some lighting strips from IKEA normally used for backlighting on a TV, they change color and they will blind you if you look directly at it.
IMGP0605 by cravinmild, on Flickr
IMGP0613 by cravinmild, on Flickr
More options whoot
