I am looking into my first water cooling build, and have been trying to decide between single or dual. Main reason I am looking at dual is if one pump fails as I will be running my computer mostly 24/7. I will be cooling 1 CPU and 2 GPU with 120.3 and 120.2 radiators. Thanks for any input.
https://linustechtips.com/topic/392003-d5-top-single-or-dual/
if you use a D5 it should last for decades
if you have the tachometer plugged into your CPU fan header there should be no problem if the pump fails because it will turn your computer off before any damage happens
https://linustechtips.com/topic/392003-d5-top-single-or-dual/#findComment-5290880
