From the "because I can" files:
SB6183...latest and greatest modem with 16 channels down and 4 up.  They made the case pretty much solid-ventilated instead of the SB6141 where only one side and the top was ventilated (the other holes were fake holes).  Looked like it was screaming for a 120mm fan on there and I said "why not push pull".  So hot glued two fractal design fans I had in storage.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/391411-push-pull-modem-air-cooling/
Lol
If you modem ever overheats I think you need to find a place for it OUT of the oven.
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
EXPERTMODE ENGAGED.
CPU  5820k - 4.0GHz @ 1.27V  |  MOBO X99-Pro  |  RAM 16GB Ballistic @ 2133MHz  |  PSU HX750i
 COOLING  Kraken X61 - 6x NF-A14 iPPC  |  DRIVES  256GB 950 Pro - 2x 1TB Travelstar - 1x 1TB WD Black
GPU  EVGA GTX980 SC |  CASE  R5  |  OS  Win 8.1 Pro  |  MISC   Cablemod C-Series White Set
